Oldsmobile Forum: 2000 Olds Bravada RPM's
Old May 6th, 2018
n1zjd n1zjd is offline
n1zjd is on a distinguished road
Howdy folks,
What should my RPM's be when going 55? Sorry for such a dumb question. I feel like my Bravada is not shifting into overdrive. Cruising at 65 rpms at 2750. 70 is 3k. Perhaps I'm wrong but I dont remember the rpms being so high at cruising speed.
A quick google search says to tap the brake while at speed and the rpms should jump up a couple hundred RPMs when it comes out of overdrive. That's exactly what happens.
Just noticed this yesterday morning headed home from work that the engine seemed to be turning much faster at the same speed I normally drive.
Thanks for any help!
Old May 6th, 2018
C&C C&C is offline
C&C is on a distinguished road
My '04 runs at approx. 2000 rpm at 65 mph. 4.2L I-6, 4L60E tranny with a 3.73 posi rear-end.
Old May 6th, 2018
That's what I thought. For some reason my rpms are much higher now. Hmmm
Old 4 Weeks Ago
AftonJay AftonJay is offline
AftonJay is on a distinguished road
that 04 is a completely different engine, 2750 at 65 sounds about right for the4.3 4L60E transmission in the 2000. I have a 99 and that is about where i am (when its working right, which it is not right now)
Old 4 Weeks Ago
C&C C&C is offline
The size of the engine is almost irrelevant; the important numbers are transmission ratio, rear end ratio and if you want to calculate rpm (at speed) you need tire diameter. With the 4L60E transmission (which has a 0.696 overdrive) with the 3.73 rear axle ratio with a 28" diameter tire, you are looking at about 2000 rpm @ 65mph. It appears to me that your tranny is not going into overdrive (thus the higher rpm). Included is a link that can calculate your rpm/mph:
https://www.crawlpedia.com/rpm_gear_calculator.htm
Old 3 Weeks Ago
I agree that the engine size is irrelevant, i was just pointing out that the newer I6 is a completely different set up than his 2000.
  #7
Old 3 Weeks Ago
C&C C&C is offline
Not trying to be contentious but here's my reasoning to his problem: same tranny, same rear diff ratio, (tire diameter different) but using the rpm calculator, he should be closer to 2000 rpm's than his stated 2750.
p.s. Since the original poster hasn't commented, our help may have gone unheeded in any event.
p.p.s. Thanks for the dialogue Jay (in any case).
  #8
Old 3 Weeks Ago
woodyBR549 woodyBR549 is offline
woodyBR549 is on a distinguished road
Guys, I do try to stick to my area of expertise, that being over in "cutlass Supreme FWD".
However, the problem being described here is very similar to 3.1's with a 4T60E. Maybe way off here but it usually ends up being the transmission. It is slipping when in overdrive, and will eventually throw the "Check Engine Light". Although the TPS and VSS can come into play here, my experience with this particular symptom ends with having the tranny rebuilt.
A well taken care of 4T60E will usually start slipping in OD at around 230K. I am willing to bet that his vehicle has high mileage and other issues as well. For comparison, I have a 95 Cutlass Supreme SL with 70,400 original miles and drives like its brand new. So, it's not the age...it's the miles.
  #9
Old 3 Weeks Ago
lshlsh2 lshlsh2 is offline
lshlsh2 is on a distinguished road
need tire size for any idea of engine rpms, without that this is worthless.
  #10
Old 2 Weeks Ago
C&C C&C is offline
The standard tire for the Bravada (2000 model) is 235x70x15, which has a diameter of 28". This is the size I'm using for my comparisons/calculations; in order to get the rpm's the original poster is seeing would require a tire around 21" (which would be ludicrous). It is pretty apparent that his overdrive gear is not engaging, and thusly, his too high of rpm, for his speed.
