Go Back   Oldsmobile Forums > Most Recent Oldsmobile Models > Oldsmobile Bravada
Oldsmobile Bravada Forum specifically intended for Oldsmobile Bravada based discussions.
Oldsmobile Forum: Dual Exhaust?
Old July 5th, 2005
stormk stormk is offline
stormk
Can you put dual exhaust on a 2000 Bravada? If so where can you find it at?
Old July 14th, 2005
Mattl's Avatar
Mattl Mattl is offline
Mattl is an unknown quantity at this point
Yes, you will need to cut off the existing pipe either before or after the catalytic converter, get a y pipe with the same dimensions, and a couple sections of straight pipe to run to the rear. Now at the rear it would be up to you whether you would want to have mufflers with tips or just the staight pipes. Keep in mind that it will affect back pressure depending on which route you go. Most all auto supply stores should carry the appropriate hardware. Napa, Autozone etc. I have not done this on my 98 Bravada however my brother has done this on his early nineties S10 blazer which essentially has the same 4.3 engine.
