Oldsmobile Forum: 99 Intrigue Cranks but will not start
Old May 26th, 2016
kingdill8 kingdill8 is offline
kingdill8 is on a distinguished road
I bought a 99 Intrigue 3.5l a few months back. The dealer told me he thought the timing chain broke because there was a loud bang and you could hear spinning. We tore into the engine to repair the timing chain only to find out that the timing chain was fine. We then put it back together and started it to see what would happen, resulting in it firing up with no problem. about a month later, I heard a bang while driving down the road. now the car will not start, it just spins and backfires. We have since replaced the cam sensor, crank sensor and fuel pressure regulator. Does anybody have another idea to try?
Old July 12th, 2018
Mn frustrated Mn frustrated is offline
Mn frustrated is on a distinguished road
Did u ever figure out what it was?
Old July 14th, 2018
wolfvan88 wolfvan88 is offline
wolfvan88 is on a distinguished road
Did the Timing chain slip a tooth due to a worn out tensioner? Hence the noise and when you tore into the engine, you put the chain back in the correct position and then later that noise was heard again, the chain slipping and now no start?
Do you have a OBD2 tester that you can connect to the computer and check for codes to see if there are any codes showing up?
Tags
99 intrigue, cam sensor, crank sensor, cranks, not start
