Oldsmobile Forum: 2000 Intrigue Fuel Sending Unit
Old April 7th, 2018
ibis64 ibis64 is offline
ibis64 is on a distinguished road
I have to repair or replace the unit on my Intrigue. Iím looking for information on where the fuel pump and the sending unit are located?
Iím getting conflicting information as to whether the unit is located in the truck or under the rear seat?
Thanks!
Old April 7th, 2018
On an Intrigue you have to drop the fuel tank. Fwiw, that's common of GM cars made around 2000.
Fwiw, I suggest that you grab a Dealer Service manual for a *2000* Intrigue on ebay, before they become even more $$$$ in cost. Last I checked, ~$150+ is common. There are fewer and fewer of those manuals out there.
Make sure you get the SAME year as your car. The 1999 and 1998 manuals have limited use for a 2000+ Intrigue. And, the 2001, 2002 manuals have other things.
Good Luck!
Old April 9th, 2018
C&C C&C is offline
The service manual for 2000 Intrigue says to remove trunk liner and then remove the access panel to gain access to the fuel sending unit.
Old April 12th, 2018
mikeaurora mikeaurora is offline
mikeaurora is on a distinguished road
I have a 2000 intrigue, found a 2001 for a neighbor and found another 2001 for a sister in law-they all have crappy fuel gauges. We all reset the odometer to zero on gas fillups, and get gas between 150 and 200 miles of local, city driving. I did drive my Intrigue to Los Angeles and back a few years ago and, on the open road, would go as much as 525 miles between fill ups (I got 32+ MPG for the entire 5600 mile round trip), but I did carry about 3 gallons of gas just in case. Horrible gas tank sensors for fuel level.
Old May 19th, 2018
sideking sideking is offline
sideking is on a distinguished road
Fuel pump sending unit
krivasolds did a fine job explaining the failure of this sending unit. He did a photostory of his repair. You can find it here:
http://99intrigue.shutterfly.com/sendingunit
Old August 17th, 2018
My 2001 started to have that issue after the deep freeze of February, 2017 when I had 1/8 of a tank of gas in it (not a good idea) and mine reads accurately when running (idle), but goes to full or empty when driving. I put about 220 or so miles per week (I drive 150 miles Mon-Fri, and Saturday is a heck of a lot), fill it up, and reset the trip. So, for the looks of it, I need to get the whole fuel pump assembly, or just that one part replaced at the repair shop I go to (it could be just bad corrosion on the terminals).
