Go Back   Oldsmobile Forums > Older Requested Oldsmobile Models > Oldsmobile Eighty-Eight (88) > Oldsmobile 88 RWD
Notices
Oldsmobile 88 RWD Forum specifically intended for Oldsmobile Eighty-Eight (88) rear wheel drive based discussions.
Oldsmobile Forum: 85 olds delta 88
Old January 16th, 2016
aatkisson89 aatkisson89 is offline
aatkisson89 is on a distinguished road
85 olds delta 88
What is the bolt pattern on a 85 olds Delta 88 and well 2013 Camaro rims hit that
Old January 17th, 2016
Rocketguy Rocketguy is offline
Rocketguy is an unknown quantity at this point
What bolt pattern do you speak of?
What does, "well 2013 camaro rims hit that" mean?
Old January 18th, 2016
amcnut amcnut is offline
amcnut is on a distinguished road
A 1985 Delta 88 would have either 5X4.75" bolt pattern, usually, or if it has heavy duty suspension (i.e. wagon) it may have 5X5" bolt pattern.
Typically Camaros and Firebirds will use the 5X4.75" bolt pattern on the wheels and as far as putting Camaro wheels on the Delta, you'd have to worry most about backspacing. I think the Camaro wheels will have too much backspacing to fit comfortably on the Delta.
Old April 19th, 2016
jamesharrell19 jamesharrell19 is offline
jamesharrell19 is on a distinguished road
Camaro is 5x120. Delta 88 is 5x4.75
Copyright ©2000 - 2018, vBulletin Solutions Inc.
